Episerver search indexing service problem
Episerver version: 7.61
Server: Windows server 2016
Requiremet server features is don,  both .net 3.5 +.net 4/4.5 Featues > WCF Service and http activations, web.config ok etc.
Still got error,  i dont get it is there something missing:
Could not find a base address that matches scheme https for the endpoint with binding WebHttpBinding. Registered base address schemes are [http].
Help!
#199787
Dec 11, 2018 14:13
Hi Kimmo,
Assuming you are running the search service in the same instance as the web site.
Didn't test but found one oldish config file from my demos (CMS 9.0.3, Search 8.0.0):
  <episerver.search active="true">
    <namedIndexingServices defaultService="serviceName">
      <services>
        <add name="serviceName" baseUri="http://localhost:15162/IndexingService/IndexingService.svc" accessKey="local" />
      </services>
    </namedIndexingServices>
    <searchResultFilter defaultInclude="true">
      <providers />
    </searchResultFilter>
  </episerver.search>
  <system.serviceModel>
    <serviceHostingEnvironment multipleSiteBindingsEnabled="true" />
    <bindings>
      <webHttpBinding>
        <binding name="IndexingServiceCustomBinding" maxBufferPoolSize="1073741824" maxReceivedMessageSize="2147483647" maxBufferSize="2147483647">
          <readerQuotas maxStringContentLength="10000000" />
        </binding>
      </webHttpBinding>
    </bindings>
  </system.serviceModel>
  <episerver.search.indexingservice>
    <clients>
      <add name="local" description="local" allowLocal="true" readonly="false" />
    </clients>
    <namedIndexes defaultIndex="default">
      <indexes>
        <add name="default" directoryPath="[appDataPath]\Index" readonly="false" />
      </indexes>
    </namedIndexes>
  </episerver.search.indexingservice>
  <location path="IndexingService/IndexingService.svc">
    <system.web>
      <httpRuntime maxQueryStringLength="65536" />
    </system.web>
    <system.webServer>
      <security>
        <requestFiltering>
          <requestLimits maxQueryString="65536" />
        </requestFiltering>
      </security>
    </system.webServer>
  </location>
So do you have the baseUri set in episerver.search?
#199800
Dec 11, 2018 21:08
Problem solved. Ssl issue, we import certificate form old server and everything is ok now.
#199804
Dec 12, 2018 9:43
