Web api in episerver doesn't work in iis
I have a web api in my EPiServer application which previously worked fine. But suddenly I can't get it to run in IIS. Localhost works fine. It seems the web api is found, but the routing is wrong. I get this error message in postman when I run (...)/api/epi/helptexts:
"Message": "No HTTP resource was found that matches the request URI '(...)/api/epi/helptexts'.",
"MessageDetail": "No type was found that matches the controller named 'helptexts'."
This is the controller:
[RoutePrefix("api/epi")]
public class ContentController : ApiController
[HttpGet]
[Route("helptexts")]
[AllowAnonymous]
public HttpResponseMessage GetHelptextsNorwegian()
This is the webApiConfig.cs:
[InitializableModule]
  [ModuleDependency(typeof(FrameworkInitialization))]
  public class WebApiConfig : IInitializableModule
      GlobalConfiguration.Configure(config =>
        config.MapHttpAttributeRoutes();
        config.EnableCors();
        var formatters = GlobalConfiguration.Configuration.Formatters;
        var jsonFormatter = formatters.JsonFormatter;
        var settings = jsonFormatter.SerializerSettings;
        var enumConverter = new Newtonsoft.Json.Converters.StringEnumConverter();
        jsonFormatter.SerializerSettings.Converters.Add(enumConverter);
        settings.Formatting = Formatting.Indented;
        config.Formatters.Remove(config.Formatters.XmlFormatter);
        config.Routes.MapHttpRoute(
          routeTemplate: "api/epi/{controller}/{id}",
          defaults: new { id = RouteParameter.Optional });
This configuration works fine in another site. Can anyone point me in the right direction?
#197628
Oct 09, 2018 9:26
I finally figured it out. I had to upgrade the .net framework from 4.5 to 4.6. I have no idea why, because everything was working fine before.
#197647
Oct 09, 2018 13:54
