That does not require Episerver Commerce, however that URI only accepts POST. If you are trying to do a GET it should not work
Thank you for the quick answer! I'll continue the investigation. It seems the documentation should be corrected. There is still:
Hi, all!
I'm trying to import images as it is described in the documentation. I get a token with "/episerverapi/token", but when I try to access "/episerverapi/commerce/import/assets", I receive 404 error. What can be the reason? Do I need Episerver Commerce to work with these methods?
