SiteDefinition.Current.SiteUrl returns null in AfterInstall()
We are trying to acces `SiteDefinition.Current` at the time of `AfterInstall`. What we need is `SiteUrl` and `Id` but it seems that at the time of this event they are not available.
How can we postpone the calling of `AfterInstall` or otherwise, could we attach an event listener in `AfterInstall` that can later in the pipeline provide us the data?
Update:
From what I can see in the documentation and from here (enumerating the order of the execution of dependencies), decorating the class like the following should have EPiServer.Web initialized, and  by extent, SiteDefinition.Current.
[InitializableModule]
[ModuleDependency(typeof(Web.InitializationModule))]
public class ModulePackageInitializer : PackageInitializer
Decorated the class like bellow with no results.
[ModuleDependency(typeof(EPiServer.Packaging.PackageInitializer))]
#181045
Aug 07, 2017 15:27
Not sure, it will solve your problem documentation says you should add dependency on  PackagingInitialization (Derived class should be marked with ModuleDependencyAttribute with dependency on PackagingInitialization.))
#181055
Aug 07, 2017 23:27
Hi Tahir,
We have tried that as well. Same result. unfortunately.
#181069
Aug 08, 2017 9:38
Just another pointer, Are you aware of "TerminateInitializationException"?
Check this link as well
https://world.episerver.com/blogs/Magnus-Strale/Dates/2009/12/The-new-initialization-system---How-to-write-an-initialization-module-and-advanced-topics/
#181074
Aug 08, 2017 10:05
No I was not aware. How can it be used?
Like this?
if (SiteDefinition.Current.SiteUrl == null)
            throw new TerminateInitializationException();
#181077
Aug 08, 2017 10:47
Effectively yes. See the URL that I pasted in last post. He is doing the same thing as you are...
#181080
Aug 08, 2017 12:05
I have seen it, but am not aware of the methods he is calling>
 var section = EPiServerFrameworkSection.Instance;
         InitializeFromConfig(section.SiteHostMapping);
         var configSiteId = SiteIdFromConfig(section); // Get info from config file /
         var actualSiteId = SiteIdFromRequest();
"InitializeFromConfig", "SiteIdFromConfig" and "SiteIdFromRequest"
#181081
Edited, Aug 08, 2017 13:01
<p>Solved with this</p> <pre class="cs hljs" contenteditable="false"><span>var</span> siteDefinitionRepository = ServiceLocator.Current.GetInstance&lt;SiteDefinitionRepository&gt;(); <span>var</span> siteDefinitions = siteDefinitionRepository.List().ToList();</pre>
#181084
Aug 08, 2017 13:55
You should use the interface instead
var siteDefinitionRepository = ServiceLocator.Current.GetInstance<ISiteDefinitionRepository>();
var siteDefinitions = siteDefinitionRepository.List().ToList();
#198412
Oct 26, 2018 14:29
