UTC convert: Site goes blank
I have a episite v10 that I want to check against a production db of version 7.5.
After I connect to the old db I get the information that the UTC-convertion is missing so I run it (from vs and package manager console, package source = episerver and Default project = "the webproject". I run the command "Convert-EPiDatabaseToUtc"). No errors but when I then go to the site the whole site is just blank and when I try to login to edit mode I get the error below after I have loged in:
The trust relationship between this workstation and the primary domain failed.
Does anyonw have any idea of why this happenas and what is missing?
#177382
Apr 10, 2017 16:04
It seems like you're using either WindowsMembershipProvider or MultiplexingMembershipProvider but you are not connected to the domain. Check your vpn settings or switch to SqlServerMembershipProvider.
#177391
Apr 10, 2017 20:05
Well the thing is that the whole page is not now going blank but large parts of its pictures and all the links goes to 404. I can in epi edit mode see that the page does exist but still I get 404.
I am lost on what could have gone wrong?
Can this happen when you make a UTC conversion?
#177449
Edited, Apr 12, 2017 8:31
Any errors in the error log? Is your local OS in the same timezone as database server? Have you updated all your nuget packages to Episerver 10?
There are quite a few breaking changes in v10.
http://world.episerver.com/documentation/upgrading/Episerver-CMS/10/breaking-changes-cms-10/
Here are some helpful links to help you debug the issue:
http://world.episerver.com/documentation/developer-guides/CMS/Deployment/storing-utc-date-and-time-in-the-database/
https://tedgustaf.com/blog/2016/upgrade-to-episerver-10/
#177764
Apr 19, 2017 4:51
I had to go into Admin and look up the blank pagetype and then click "revert to standard settings".
Nope that did not do the trick for every pagetype. I have web form code together with MVC code and the pages that are web forms is now getting errors after "revert to standard settings". Can I do something to prevent the web forms page types from breaking?
#177774
Edited, Apr 19, 2017 11:05
