"The wait operation timed out"
While developing under IIS express, I get intermittent yellow screens of death with "The wait operation timed out".
This is the full response:
https://pastebin.com/L3frVUMH
Rebuilding doesn't fix it. Cleaning and rebuilding doesn't fix it. Stopping IIS Express and re-running doesn't fix it. Closing the solution, reloading, and re-running doesn't fix it. What fixes it, is shutting down Visual Studio entirely and reopening.
This doesn't seem to be a commonly known issue, I haven't been able to narrow it down to specifics as to why it happens, but I think it's related to adding or removing properties on content types (doesn't happen every time I add or remove them so I can't confirm).
Visual Studio 2017
Build 15.0.0-RTW+26228.4
Latest EPi version.
I've fiddled with empty Alloy, Alloy Demo Kit, and Quicksilver over past three months, ran into this issue with all of them. Running into the issue on a daily basis currently, so decided to make a topic.
#177996
Apr 26, 2017 12:56
To add to this:
I'm fairly certain the reason is removing or adding properties. I've been running into a 504's when I've started deploying it DXC. Thankfully this is resolved after a few refreshes, but I'm conscious of a few other topics that have mentioned timeouts. No configuration settings I have tried to increase timeout, be it in connectionstring or using the dataStore configsection, have worked.
I'm erratically able to resolve this issue occasionally by changing web.config to force a restart, but it doesn't work every time, and seems to take 4-5 re-updates to fix, other times I will give up after 5 tries and just restart visual studio.
What is going on here and how do I get Epi to not time out?
#178155
May 03, 2017 10:22
