The object has not yet been initialized. Ensure that HttpConfiguration.EnsureInitialized...
After doing a test upgrade to the very latest EPiServer version, along with 'EPiServer.Marketing.Testing 2.2.3', I'm now facing the following error when calling my own Web API:
The object has not yet been initialized. Ensure that HttpConfiguration.EnsureInitialized() is called in the application's startup code after all other initialization code.
Does anyone have a way of resolving this issue?
The start of my Global.asax.cs looks like this:
public class Global : EPiServer.Global
        protected void Application_Start()
			// Enabling bundling and minification
			BundleConfig.RegisterBundles(BundleTable.Bundles);
			// Enable Web API routing
			GlobalConfiguration.Configure(config =>
				// Activate CORS
				config.EnableCors();
				// Attribute routing
				config.MapHttpAttributeRoutes();
				// Convention-based routing
				config.Routes.MapHttpRoute(
					routeTemplate: "webapi/{controller}/{action}/{id}",
					defaults: new { id = System.Web.Http.RouteParameter.Optional }
I've tried adding GlobalConfiguration.Configuration.EnsureInitialized(); to a couple of places but it still won't work.
Thanks in advance!
#178045
Edited, Apr 27, 2017 16:09
I think this is missing from your
Application_Start
GlobalConfiguration.Configure(WebApiConfig.Register);
#178064
Apr 28, 2017 11:15
If I try
it means I have to move the configuration code to its own class, right?
I tried this:
public static class WebApiConfig
		public static void Register(HttpConfiguration config)
			// Activate CORS
And adding
But it's still not working.
Seems weird that my own WebAPI stops working just because I upgrade EPiServer, adding 'EPiServer.Marketing.Testing 2.2.3''.
#178065
Apr 28, 2017 11:39
Without trying, I think it should look like this
                                WebApiConfig.Register();
				// Activate CORS
#178079
Edited, Apr 28, 2017 15:25
<p>But won't the code<br /><br />WebApiConfig.Register(...)<br /><br />do the same thing as the rest of the code below it? Registering the same stuff twice will result in an exception.</p>
#178112
May 02, 2017 10:26
I managed to solve it by using the following code:
[InitializableModule]
[ModuleDependency(typeof(EPiServer.Framework.FrameworkInitialization))]
public class MyInitializationModule : IInitializableModule
			// Activate CORS
#178125
May 02, 2017 15:43
<p>I've implemnted the above method but get this error:</p> <p></p> <h2>A route named 'MS_attributerouteWebApi' is already in the route collection. Route names must be unique.<br />Parameter name: name</h2> <p>we already have a&nbsp;WebApiConfiguration</p> <p></p> <pre class="brush:csharp;auto-links:false;toolbar:false" contenteditable="false"> public static class WebApiConfiguration { public static void Register(HttpConfiguration config) { config.MapHttpAttributeRoutes(); config.Routes.MapHttpRoute( "DefaultApi", "api/{controller}/{id}", new {id = RouteParameter.Optional} ); config.EnableCors(new CorsAccessPolicy()); config.EnsureInitialized(); var appXmlType = config.Formatters.XmlFormatter.SupportedMediaTypes.FirstOrDefault(t =&gt; t.MediaType == "application/xml"); config.Formatters.XmlFormatter.SupportedMediaTypes.Remove(appXmlType); }</pre> <h2>and also a&nbsp;WebApiConfig&nbsp;</h2> <pre class="brush:html;auto-links:false;toolbar:false" contenteditable="false"> public static class WebApiConfig { public static void Register(HttpConfiguration config) { // Web API configuration and services // This handler is for cors // removing CORS can be controlled from Azure //config.MessageHandlers.Add(new CrossDomainHandler()); config.Services.Replace(typeof(IExceptionHandler), new CustomExceptionHandler()); config.Routes.MapHttpRoute( name: "WebApiRoute", routeTemplate: "api/{controller}/{id}", defaults: new { id = RouteParameter.Optional } ); </pre> <p>I tried several time by removing MapHttpRout statement from one and the both files but still have the same issue.</p> <p>We use Episerver &nbsp;ServiceAPI in our project as well</p>
#182924
Oct 02, 2017 7:26
Try removing  config.MapHttpAttributeRoutes(); in your WebApiConfiguration.Register - ServiceAPI already calls this
#182932
Oct 02, 2017 8:38
I had removed MapHttpAttributeRoutes as well but got the following message even when I add
to the config file and initialize module
#182987
Oct 03, 2017 2:24
I already add this line to Application_Start , but got same message:
#182992
Oct 03, 2017 8:00
Adding this line to web.config fix the problem:
<add key="episerver:serviceapi:maphttpattributeroutes" value="false" />
#183523
Oct 17, 2017 5:00
Billy - Nov 15, 2022 15:55
This web config change worked for me. I think the root issue might be with how some are implementing IDependencyResolver and adding it to GlobalConfiguration.
- Oct 02, 2024 12:51
This was almost the solution (for me) but not quite. I needed to add (note the "healthcheck" section):
< add key="episerver:healthcheck:maphttpattributeroutes" value="false" / >
Apparently, this is caused after installing the EPiServer.CloudPlatform.Cms package.
