If you have your visitor group, something like this should be able to tell you if the visitor group is active for the current request:
VisitorGroupRole virtualRoleObject;
if (_visitorGroupRoleRepository.TryGetRole(visitorGroup.Name, out virtualRoleObject))
return virtualRoleObject.IsMatch(httpContext.User, httpContext);
Regards
Per Gunsarfs
Thanks for the suggestion Per! I will try and implement this. Will come back and mark it if(when) I get it to work :-)
This part:
Is giving me some issues, I have implemented an IPrincipal called Principal which I use at the httpContext.User part - since it wants an IPrincipal. But the secondary part wants a HttpContextBase. But if I create one it wont accept it..
How do I use these? Do you have a working example I could take a look at - where you see if a Visitor Group is triggered or not?
I really appriciate any help.
This code was from an example where we check if a visitor group would be applied to a specific request. The easiest way to get those arguments is to use the HttpContext.Current. Something like:
var httpContext = new HttpContextWrapper(HttpContext.Current);
The HttpContextWrapper is simply there to wrap the HttpContext into an HttpContextBase.
Thanks for you help! It works now. I made your first suggestion work :-)
I am trying to get a hold of which Visitor Group is active. The ultimate goal is to send it as a dimension to Google Analytics. First step here though is just to see if I can catch which Visitor Group is triggered. On my front page I currently have a test Visitor Group that is always triggered so that is the one I am expecting to see.
I can get my visitor groups via this:
var visitorGroup = new VisitorGroupStore(this.DataStore, ServiceLocator.Current.GetInstance<>ISynchronizedObjectInstanceCache>()).List();>
This show me all (5) visitor groups that I have made. I am now missing the link on how to see if a visitor group is active or not.
I am wondering if "PrincipalInfo" somehow should be used here?
I have a controller with a method that returns me a partial view with a string model that hopefully will contain the active visitor group(s).
Is there any of you that can point me in the right direction?
