I've done the following for saving the file size, guess you could do something similar to populate Height and Width.
[InitializableModule]
public class FileInitialization : IInitializableModule
var eventRegistry =
ServiceLocator.Current.GetInstance<IContentEvents>();
eventRegistry.CreatingContent += OnCreatingContent;
eventRegistry.SavingContent += OnSavingContent;
private void OnSavingContent(object sender, ContentEventArgs e)
var content = e.Content as MediaData;
if (content == null || !(content is ISearchableFile))
return;
var fs = content.GetFileSize();
((ISearchableFile)content).FileSizeInKb = (int)fs;
private static void OnCreatingContent(object sender, ContentEventArgs e)
return;
I would go with Erik's approach. Mark Everard has a good example on how to get the dimensions: https://github.com/markeverard/Chief2moro.ImageDataExtensions/blob/master/src/Chief2moro.ImageDataExtensions/ImageBlobUtility.cs
Also, I would add the [Editable(false)] attribute to the properties, as this would be read-only properties.
This is awesome! exactly what I was looking for.
Thanks guys! Thanks a lot!
I need to have some properties on my images like their original size (width and height), so I've inherited from ImageData like this:
But of course those files are not filled. How can I fill them everytime someone uploads an image, or edit the one related?
I was hoping to find a class that I can extend for this but ContentMediaHttpHandler that has been mentioned in the documentation is not there and I don't like to implement a media handler from scratch.
Where shall I fill the fileds?
