How to activate TinyMcespellchecker addsOn?
Hello,
I have put the TinyMcespellchecker.zip, module.config, web.config files under the modules/_protected. How the function should be activated for the editor?
Thkans a lot.
/Fang
#175268
Feb 15, 2017 14:46
Go to Admin -> Config -> Property Configuration -> Edit Custom Property Types
Select XHTML string (>255)
In the bottom now you will see tinyMCE Editor, select on that you use and there you can add the spellchecker plugin.
#175272
Feb 15, 2017 15:46
Thanks a lot. It dit work.
Now I need to add the dictionary for Swedish just.
#175274
Feb 15, 2017 16:00
