Cannot switch language on sites tab
Hello,
Trying to switch language from sites tab it redirect me to wrong url
"https://xxxxx/cms/CMS/?language=en&language=en#context=epi.cms.contentdata:///5780&viewsetting=viewlanguage:///en,en"
If I remove "&language=en" it work normally.
Does anyone know how to fix this? Thanks.
#175499
Edited, Feb 22, 2017 8:05
The language switcher was a bit buggy in earlier versions of Episerver 7. What Episerver version are you using?
#175505
Feb 22, 2017 10:38
Im using Episerver 9.7.2
#175506
Feb 22, 2017 10:45
Are you using the Rewrite-module in IIS for your EpiServer?
We had the same problem, and the reason was a misconfiguration in our rewrite-rule in IIS that redirected all traffic to use HTTPS.
Our rule had the following redirect-action:
<action type="Redirect" url="https://{HTTP_HOST}{REQUEST_URI}" redirectType="Permanent" />
We changed it to:
<action type="Redirect" url="https://{HTTP_HOST}{REQUEST_URI}" redirectType="Permanent" appendQueryString="false" />
This stopped the server from adding the same querystring twice and solved the problem with switching languages in EpiServer.
#175811
Edited, Mar 02, 2017 16:56
