SimpleAddress from PropertyUrl
  1.  I have certain page having both long (Page1/Page2/MyPage) and simple (MyPage) addresses.
  2.  Then I want to reference it in certain place via PropertyUrl:
            [CultureSpecific]
            [Required]
            [BackingType(typeof(PropertyUrl))]
            [Display(
                Name = "Link",
                Description = "Link to the page",
                Order = 1)]
            public virtual Url Link { get; set; }
  3.  I want the simple address (if it exists) to be used for the routing or url rendering but not the long one.
I am looking for some elegant solution for it if it exists. Thanks in advance
#174314
Jan 24, 2017 12:07
If you don't need the PropertyUrl requirement, you can use a ContentReference instead and use an extension to get the simple url.
using EPiServer;
using EPiServer.Core;
using EPiServer.DataAnnotations;
using EPiServer.ServiceLocation;
using EPiServer.Web.Routing;
namespace ExampleExtensions
    public static class ExampleContentExtensions
        static Injected<IContentLoader> _ContentLoader;
        public static string GetUrl(this ContentReference contentReference)
            if (ContentReference.IsNullOrEmpty(contentReference))
                return "#";
            var content = _ContentLoader.Service.Get<IContent>(contentReference);
            var externalProperty = content?.Property["PageExternalURL"];
            if (!string.IsNullOrWhiteSpace(externalProperty?.ToString()))
                return string.Format("/{0}/", externalProperty.ToString().Trim('/'));
            return UrlResolver.Current.GetUrl(contentReference);
    public class PageBase : PageData
        [CultureSpecific]
        [AllowedTypes(typeof(PageData))]
        public virtual ContentReference LinkToContent { get; set; }
#174324
Jan 24, 2017 14:59
Thanks Brad,
I was looking for this kind of solution, but it was not working with PropertyUrl...
As I can see here they are using not only the Page references, but links to the catalogs (from EpiCommerce)... and I am not sure if they could reference here on other features of PropertyUrl... So I am looking the solution for PropertyUrl at the moment
#174327
Edited, Jan 24, 2017 15:12
I've not tested, but this may work for you. It should support Url, ContentReference, and IContent.
using EPiServer;
        public static string GetUrl(this Url url)
            var content = UrlResolver.Current.Route(new UrlBuilder(url));
            return GetUrl(content);
            if (ContentReference.IsNullOrEmpty(contentReference)) return "#";
            var content = ServiceLocator.Current.GetInstance<IContentLoader>().Get<IContent>(contentReference);
        public static string GetUrl(this IContent content)
            if (content == null) return "#";
            return UrlResolver.Current.GetUrl(content.ContentLink);
#174333
Jan 24, 2017 15:44
Thank you a lot, Brad!
I'll try this solution.
Upd: It works fine. Thanks!
#174334
Edited, Jan 24, 2017 15:56
Still could not mark Brad's post as an Answer... Image
#174379
Edited, Jan 25, 2017 10:56
