There is an overload to the constructor when creating the LogInterceptor that takes both the object dumper to use and the logger. So its possible the hard way by implementing the matching interface and use your favorite way. Ill also add a simple way to use your own json serialization settings in next release. Let know how it works out on on daniel.ovaska at mogul.com.
I was reading Daniel's blog about adding logging, and I am coming across a problem with the JSON serialization settings. The issue is that I want to set the settings for the Dump method. I would like to set the ReferenceLoopHandling setting to be equal to ReferenceLoopHandling.Ignore, but I cannot see how to get access to the json settings to set this. Does anybody have any ideas?
