get html of XHTML property with nested block via ajax
Hi all,
I need to get XHTML property of my block using ajax.
If I add a different block into RTE, if I call
_contentLoader.Get(id).Description.ToHtmlString(),
I get
quote
as a part of html string and if I call
_contentLoader.Get(id)?.Description?.ToInternalString()
I get "".
What is the correct way of getting full correct html (including internal block html) from RTE property in ApiController?
#151714
Aug 04, 2016 14:26
Don't know if this is the correct way but I'm using this approach:
public class DummyController : Controller
public static class XhtmlStringExtensions
    public static string ToParsedHtmlString(this XhtmlString xhtmlstring)
        if (xhtmlstring == null || xhtmlstring.IsEmpty || string.IsNullOrWhiteSpace(xhtmlstring.ToHtmlString()))
            return string.Empty;
        var routeData = new RouteData();
        routeData.Values.Add("controller", "a");
        var hh = new HtmlHelper(new ViewContext()
            HttpContext = new HttpContextWrapper(HttpContext.Current),
            ViewData = new ViewDataDictionary(),
            TempData = new TempDataDictionary(),
            Controller = new DummyController(),
            RouteData = routeData
        }, new ViewPage());
        string result;
        using (var writer = new StringWriter())
            hh.ViewContext.Writer = writer;
            hh.RenderXhtmlString(xhtmlstring);
            writer.Flush();
            result = writer.ToString();
        return result;
#152019
Edited, Aug 12, 2016 13:43
