unable to save robots.txt content
Hello.
Anyone know how I can debug robots.txt functionality in episerver 6?
After installing this in Package Manger Console:
Install-Package EPiRobots -Version 1.0.1
I am able to view "Manage robots.txt content" in Admin > Tools. All the sites are listed in the dropdown after "Select your site and host to edit the robots.txt file".
However, if I try to "Save" the content of robots.txt I get:
Index was outside the bounds of the array.
Exception Details: System.IndexOutOfRangeException: Index was outside the bounds of the array.
Source Error:
Stack Trace:
[IndexOutOfRangeException: Index was outside the bounds of the array.]
EPiRobots.Resources.Admin.AdminManageRobotsTxt.btnSave_Click(Object sender, EventArgs e) +925
System.Web.UI.WebControls.Button.OnClick(EventArgs e) +11762637
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +150
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +6016
WHat is a good way to debug this to figure out the root cause?
#151611
Edited, Jul 31, 2016 19:16
Hello Singo
More information about the module can be found here:
http://www.david-tec.com/2011/07/EPiRobots-A-generic-robotstxt-handler-for-your-EPiServer-CMS-6-R2-site/
The source code is available here so can use this for debugging the cause:
http://epirobots.codeplex.com
David
#151622
Aug 01, 2016 9:54
#151659
Aug 03, 2016 9:05
<p>Thanks but it no work using that. I think the library is faulty. Has anyone else been using it with success? There's a problem with saving the robots.txt </p>
#151660
Aug 03, 2016 9:14
Hello Ringo
Thanks for the feedback. The version of EpiRobots you are using has been downloaded 311 times from the Episerver Nuget Feed and is compatible with Episerver CMS 6 R2. It was never tested for use with Episerver CMS 6 so I cannot confirm if it will work or not. However I know of several Episerver CMS 6 R2 projects that are using it sucessfully in production.
As an open source project you are welcome to submit a patch once the source of any issue is found.
David
#151664
Aug 03, 2016 10:50
