Have you tried to set the default values on the local block through the shared block's SetDefaultValues?
Example:
LocalBlock.PropertyOnLocalBlock = "value";
You probably know this, but also be aware of that SetDefaultValues only kicks in when creating the content type.
Yeah your suggestion does not work. But I did find a solution ... strangely enough this works:
LocalBlock.Property["PropertyOnLocalBlock"].Value = "value";
Does not seem to work ... data specified is not set.
The local block is inside another shared block, and i can set default values on other properties on the shared block (just not the properties on the local blocks)
