Can you setup ignore routing in EPi?
I have an existing website - a WebForms project - that hooks into EPiServer. Call it www.example.com.
EPi is on control of routing, though I am unsure how it manages routing (newbie).
I would like to build out a new route - call it www.example.com/app - using a new WebForms page/code-behind and (important!) will not result in 404 from EPi.
In fact, I would like EPi to ignore www.example.com/app and all of its child routes completely, allowing me to build the base page for a new SPA within the existing website. Allowing me to have
  • www.example.com/app
  • www.example.com/app/cool-thing-1
  • www.example.com/app/cool-thing-1/12345
  • www.example.com/app/cool-thing-2
  • etc
Basis for the request is to create something akin to an index.html or index.aspx in that ignored location within the folder structure of the existing WebForms project, and load a SinglePageApplication within it.
I have attempted this, but EPi results in 404s for the SPA's routed views. Other words, www.example.com/app may load in the browser, but all routed templates result in 404s.
Is there a recommended approach for handling this problem? Was thinking of establishing ignore routes, but with EPi in control of routing, I wasn't sure where to start. Any guidance is appreciated.
#150977
Jul 05, 2016 18:46
First register a route for your webform pages. You can do this in global.asax by overriding the RegisterRoutes method:
public class EPiServerApplication : EPiServer.Global
        protected override void RegisterRoutes(System.Web.Routing.RouteCollection routes)
            base.RegisterRoutes(routes);
            routes.MapPageRoute(
                "SPARoute",
                "App/{firstLevel}/{secondLevel}",
                "~/Views/SPAStartPage.aspx", false, new RouteValueDictionary() { { "firstLevel", string.Empty },{"secondLevel", string.Empty } }
I created a new route that match basically everything below /App and routes this to the webform page at /Views/SPAStartPage.aspx.
At this page you can now get the route values like:
<form id="form1" runat="server">
    <div>
        Hello SPA world!<br/>
        Querystring parameters:<br/>
        First Level: <%=RouteData.Values["firstLevel"]%><br/>
        Second Level: <%=RouteData.Values["secondLevel"]%><br/>
    </div>
</form>
Hope that gets you started on you SPA :)
Happy coding!
#150979
Jul 05, 2016 20:19
