IList as a field in a Block
Hi All,
Very recently I came to know that I could have IList as a field in a Block. Following is the field I have added.
[EditorDescriptor(EditorDescriptorType = typeof(CollectionEditorDescriptor))]
        [Display(
            Name = "Section",
            Description = "Add sections here",
            Order = 6)]
        public virtual IList Sections { get; set; }
        [PropertyDefinitionTypePlugIn]
        public class DishPropery : PropertyList
            protected override MenuSectionBlock ParseItem(string value)
                return JsonConvert.DeserializeObject(value);
            public override PropertyData ParseToObject(string value)
                ParseToSelf(value);
                return this;
With this implementation I am now able to add data but am not able to view the same in Preview/Edit mode unless I publish the block. Is the code missing something?
#148861
May 25, 2016 13:10
