Localization in Range attribute
Hello!
How should the path to the resource string containing error messages should be passed to Range attribute in int properties?
I have declared the property like this:
[Display(
           Order = 150)]
        [Range(1,5, ErrorMessageResourceName = "/contenttypes/icontentdata/errormessages/invalidamountnews")]
        public virtual int AmountItems { get; set; }
And then in language file:
            Nyckelord
            Beskrivning
            Stor innehållsyta
            Brödtext
            Brödtexten visas i sidans centralyta. Via XHTML-editorn kan du infoga exempelvis text, bilder och tabeller.
          Antalet att visa kan inte vara mindre än 0
This is not working and the property view for the pages of the page type loads forever, so I guess I'm passing the wrong path to the attribute. Can't find any good example either.
Does anybody have any suggestions?
/Kenia
#145831
Mar 14, 2016 9:08
In stead of
use
[Range(1,5, ErrorMessage = "/contenttypes/icontentdata/errormessages/invalidamountnews")]
However this will still not display your error message all the time.
If you enter an invalid value like "abc" you will see your error message.
If you enter a valid integer that is out of range you will see the default error message.
I haven't found a solution for this other than writing my own validator.
/Mark
#145835
Mar 14, 2016 10:06
Works like a charm. Thanks Mark!
/Kenia
#145840
Mar 14, 2016 10:38
