How to get tinyMCE to show up in an Xhtml field?
I am creating a page property that has Xhtml type. Yet when it renders  TinyMCE doesn't appear.  It was showing before when there was only one Xhtml field in that tab.
What am I doing wrong? How can I fix this?
#145310
Mar 01, 2016 20:39
Related queston. I am not able to save changes in these fields. Is this connected with my not being able to display TinyMCE here?
#145311
Mar 01, 2016 20:42
What version are you using? There was quite a few bugs in earlier versions of Episerver 7 with xhtml fields that were later fixed...Can you also copy paste the property code?
#145320
Mar 01, 2016 23:23
We are using version 8.11  Here are the fields of interest
  [CultureSpecific]
        [Editable(true)]
        [Display(
            Name = "Lobby Warning Text",
            Description = "Modal Dialog Text",
            GroupName = TabNames.SiteSettings,
            Order = 1400)]
        public virtual XhtmlString ModalDialogText { get; set; }
        [CultureSpecific]
        [Editable(true)]
        [Display(
            Name = "Hatch Act Warning (elections) Text",
            Order = 1600)]
        public virtual XhtmlString HatchActWarningText { get; set; }
#145378
Mar 02, 2016 17:43
