Getting block data from ContentRepository
I've inherented an Episerver website, making me a newbie once again.  My current task is to move a slider type content area off of a page template into a "block with blocks" configuration, in order to have more granular content scheduling for that page.
I'm stuck trying to move the property that points to the page data:
protected HomePage HomePageData
get
return ContentRepository.Get(PageReference.StartPage);
Into something that points to the containing block data, for example:
protected UpcomingEventsBlock UpcomingEventsData
get
return ContentRepository.Get(contentLink);
Mark
#145144
Feb 25, 2016 18:43
Oops, here's the code formatted:
            get
                return ContentRepository.Get<HomePage>(PageReference.StartPage);
To something like:
            get
                return ContentRepository.Get<UpcomingEventsBlock>(contentLink);
#145146
Feb 25, 2016 20:04
What is the question?
#145153
Feb 25, 2016 21:28
Sorry Bob, I realize I've not been clear on that.
I've not been able to find the correct parameter for the ContentRepository.Get method.  There is no Block equivalent to the PageReference class, that I can find.  I've tried a large number of variations but I'm mostly flailing in the dark.
If you could point me to relevant documentation or examples that would be a huge help.
#145157
Feb 25, 2016 22:06
Try ContentReference, which PageReference inherits from.
#145158
Feb 25, 2016 22:15
Thanks Johan, that sounds good, but I was not able to get it to work with any of ContentReference's methods, such as StartPage or RootPage.
This makes me realize that the original home page code is not a good model to follow. PageReference.StartPage, as far as I understand it, is a global kind of reference, a 'hard coded' pointer to the home page.  The code I'm trying to move over to a block is doing a data bind for the child blocks:
 rptSlider.ItemDataBound += BindEvents;
            if (UpcomingEventsData.ThisWeekEvents != null && UpcomingEventsData.ThisWeekEvents.Count > 0)
                var allEvents = UpcomingEventsData.ThisWeekEvents.FilteredItems
                    .Select(content => ContentRepository.Get<HomePageEventBlock>(content.ContentLink))
                    .Cast<IFeaturedEvent>().ToArray();
                var groupings = new List<FeaturedEventGrouping>();
                var curGrouping = new FeaturedEventGrouping();
                for (int curIndex = 0; curIndex < allEvents.Count(); curIndex++)
                    var curEvent = allEvents[curIndex];
                    curGrouping.Events.Add(curEvent);
                    if (curGrouping.IsFull || curIndex == allEvents.Count() - 1)
                        groupings.Add(curGrouping);
                rptSlider.DataSource = groupings;
                rptSlider.DataBind();
Where the UpcomingEventsData property is pointing to the container block.
#145159
Feb 25, 2016 22:37
Found it!  Thanks to Dan Matthews and Alf Nilsson The key was in this thread:
http://world.episerver.com/Forum/Developer-forum/EPiServer-7-CMS/Thread-Container/2013/7/Block-ContentReference-ID/
"If you cast CurrentBlock to IContent you will be able to access data from the IContent Interface."
So now I have:
            get
                var contentLink = (CurrentBlock as IContent).ContentLink;
And it works like a charm.
#145187
Feb 26, 2016 18:26
