Get Local MediaData
I'm new to EPiServer and I am trying to get all the MediaData from a local folder of a page that is not the root. I have tried to get it with the following code but I get zero back. I am doing something wrong because I have a file in my currentPage? Any ideas?
contentRepository.GetChildren(CurrentPage.ContentLink).ToList()
#145199
Feb 27, 2016 22:30
Check out the contentassetshelper class and the GetOrCreateMediaAssetsFolder method.
http://world.episerver.com/documentation/Class-library/?documentId=cms/7.5/82E86AC1
Then you can list children from that one...the method above will return an assets folder which has a content link property. Use that in your list children method above as root.
#145200
Edited, Feb 28, 2016 7:52
I have tried it but I do not get the files under currentPage using GetOrCreateAssetFolder.
            var contentAssetFolder = contentAssetHelper.GetOrCreateAssetFolder(CurrentPage.ContentLink);
#145201
Feb 28, 2016 11:24
contentRepository.GetChildren<ContentFolder>(contentAssetFolder.ContentLink)
I have tried getting all children using the abov without getting my file.
#145202
Feb 28, 2016 11:25
Have you tried.GetChildren<IContent>(contentAssetsFolder)?
That should give you everything in page files. In your above code you are asking for any children of type content folder, so it won't give you normal images etc.
#145203
Edited, Feb 28, 2016 12:10
Thank you :)! Works like a charm!
#145205
Feb 28, 2016 17:28
Sweet! Remember to filter them on access rights and publish status since GetChildren doesn't do that by default. :)
I normally use FilterForVisitor in Episerver.Filters namespace...or an extension that looks a little prettier.
#145206
Edited, Feb 28, 2016 17:46
