EPiServer 8: Navigate by template and ID
Is it still possible in some way to access a certain page by it's template and id? We have a site that's been migrated to CMS 8 and a function that uses this has stopped working.
In earlier versions it was possible to access it as such: mywebsite.com/myTemplate.aspx?id=82
#144743
Feb 18, 2016 11:41
No need for a template any more. The URL structure is as follows:
http://[your-site]/EPiServer/Cms/#viewsetting=viewlanguage:///[content-langauge]&context=epi.cms.contentdata:///[id-of-the-content]
So for your example you should be able to use something like:
http://www.yoursite.com/EPiServer/Cms/#viewsetting=viewlanguage:///da&context=epi.cms.contentdata:///82
#144746
Feb 18, 2016 11:51
But this is only for logged in users. I want to request the site as a visitor.
We have an old javascript that fetches the ID of the page we want to insert and then builds a request from that.
#144750
Feb 18, 2016 12:04
If you are using MVC this will probably not be possible without some customisation. I've never tried it with WebForms in CMS 7+ if I am honest.
It sounds like there may be some alternatives - what is your specific requirement?
#144752
Feb 18, 2016 12:07
If there's no other way, maybe I should rewrite the code then.
We have a site with a control on it. The control has data that's changing through ajax depending on what option the visitor is clicking on. The list of options is a li with a data-attribute with the ID of the page that is supposed to be fetched. On the onClick event the script fetches that page and displays it. I will try to rewrite it if it's not possible anymore to fetch a site only with ID through the browser.
#144753
Feb 18, 2016 12:11
One elegant way to solve the problem would be to simply render the fully qualified URL into markup for AJAX request and let the code continue as before.
#144754
Feb 18, 2016 12:16
Yeah, I thought so to. Will do that. Thanks for the help!
#144755
Feb 18, 2016 12:19
