Change /link/ to /"sitename"link/ ?
Hello!
Is there a way of changing episervers /link to for example /"sitename"link ?
www.xxx.com/link/..... => www.xxx.com/xxxlink/....
#173244
Dec 16, 2016 16:30
Not sure if I understand what you mean. But you can for example use the CreatedUrlSegment-event and always prepend the name with sitename.
An example of using the event
#173259
Dec 18, 2016 23:33
I have a multi license. There are two sites A and B.
Site A has a host www.a.com and site B has a host www2.a.com.
The domain www2.a.com is then, outside of epi, redirected to www2.a.com/site (the server has a rule redirecting the root host www2.a.com to www.a.com as well).
This of course causes problems to site B regarding episervers use of permanent links.
The business does not want to give site B its own domain. It should look like it belongs to www.a.com therefor the use of www2.a.com (that is a subdomain to www.a.com).
Is there a way for me to somehow resolve this issue without changing the hosts of the sites? Is there a way in some config or such that I can change so that the server will know where to route the permanent links like www2.a.com/link/....
Or is there a way of changing the url from www2.a.com/link/.... to www2.a.com/something/link/.... ?
#173285
Edited, Dec 19, 2016 15:55
