Looks like it's trying to find some VPP (virtual path) settings and not finding any?
Check documentation and see if you need something specific? Test installing it on a fresh demo site of the same version...
Hi All,
b__4() +19 >
I'm working on installing this plug-in within my development environment and I followed all the steps within usage instructions document and I believe the setup is correct but I think there could be something as at play here in terms of my EPiServer configuration and how it integrates with the plug-in. I used the NuGet package manager within visual studio to install it and below is the full stack trace of the error. I've researched other posts regarding the use of this plug-in and associated issues but it doesn't appear that anybody has run across this particular issue. Any thoughts you have would be greatly appreciated.
System.Configuration.ConfigurationElement.get_Item(String propertyName) +654793
EPiServer.Configuration.EPiServerSection.get_VirtualPathSettings() +10
FortuneCookie.EPiServer.SearchAndReplace.RegisterResources.GetEPiServerCmsPath() +43
FortuneCookie.EPiServer.SearchAndReplace.RegisterResources.RegisterVppResources() +145
FortuneCookie.EPiServer.SearchAndReplace.RegisterResources.Start() +8
System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) +0
System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) +192
System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +108
System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams) +1788
EPiServer.PlugIn.PlugInRuntime.Start(Boolean reset) +311
EPiServer.Initialization.PlugInInitialization.Initialize(InitializationEngine context) +10
EPiServer.Framework.Initialization.<>c__DisplayClass5.
EPiServer.Framework.Initialization.ModuleNode.Execute(Action a, String key) +43
EPiServer.Framework.Initialization.ModuleNode.Initialize(InitializationEngine context) +80
EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +349
EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType) +118
EPiServer.Framework.Initialization.InitializationModule.Initialize(HostType hostType) +353
EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +82
EPiServer.Global..ctor() +79
Shedd.Web.Global..ctor() +29
ASP.global_asax..ctor() in c:\Users\earnquist\AppData\Local\temp\Temporary ASP.NET Files\vs\2856dfe4\39a9fddb\App_global.asax.meh2thet.0.cs:0
System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +113
System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +232
System.Activator.CreateInstance(Type type, Boolean nonPublic) +83
System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1136
System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +128
System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +18
System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +60
System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +260
System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +296
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9952212
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +101
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +254
Eric
