If the list should contain all categories defined in EPiServer you can remove the SelectOneAttribute from your property. This is the only thing you need:
[Display(Name = "Category Selection", Order = 1)]
public virtual CategoryList Category { get; set; }
I'm trying to create an MVC block which will allow the user to select a category from all available categories to affect some programatically defined items. (IE Select 'shoes' to show some calculated shoe results, or 'TVs' etc etc)
In my block definition I have:
[Editable(true)]
Order = 1)]
[SelectOne(SelectionFactoryType = typeof(CategorySelectionFactory))]
Which I was hoping would give me a select list of available categories for the user to choose from. However when I'm running the solution and going to the block I'm getting the following error:
Unable to cast object of type 'EPiServer.Business.Commerce.VisitorGroupsCriteria.CategorySelectionFactory' to type 'EPiServer.Shell.ObjectEditing.ISelectionFactory'
But from what I can see CategorySelectionFactory does implement ISelectionFactory, so I'm not sure what I'm missing here to cause this error. If I am meant to inject an instance of CategorySelectionFactory I'm not sure how to do that for an MVC block.
Sorry if this is a relatively basic question, I'm relatively new to EPiServer development, and any help would be appreciated.
