Page Could not be loaded
Hi All
We are using EPi-Server CMS 6.1 R2, Now a days frequently we are getting below error while editing a page in EPi EDIT mode.
Could you please help us in getting this issue resolved.
2015-09-08 13:20:11,558 ERROR [13] EPiServer.Global.Global_Error - 1.2.5 Unhandled exception in ASP.NET
System.Web.HttpUnhandledException: Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at EPiServer.Editor.AutoSave.AutoSaveRepository.<>c__DisplayClass5.b__4(Draft draft)
at System.Linq.Enumerable.<>c__DisplayClassf`1.b__e(TSource x)
at System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext()
at System.Linq.Enumerable.d__81`1.MoveNext()
at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at EPiServer.UI.Edit.EditPageButtonControl.CheckEditingStatus()
at EPiServer.UI.Edit.EditPageButtonControl.OnPreRender(EventArgs e)
at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.epiui_cms_edit_editpanel_aspx.ProcessRequest(HttpContext context)
2015-09-08 13:20:18,714 ERROR [8] EPiServer.Global.Global_Error - 1.2.5 Unhandled exception in ASP.NET
2015-09-08 13:20:24,135 ERROR [23] EPiServer.Global.Global_Error - 1.2.5 Unhandled exception in ASP.NET
#133717
Sep 09, 2015 11:53
Hi Waquar,
you can copy all the dll's from   below folders to your bin folder.
C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\bin
C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\bin
Regards
Venkata Phani kumar R
#133753
Sep 10, 2015 5:45
Hi, you can disable the auto save-functionality by adding autoSaveInterval="0:0:0" to <sitesettings ... > in EPiServer.config.
#133781
Sep 10, 2015 13:39
