Is this problem isolated to ApiControllers? Do you experience the same problem if you run the code from a page template?
Hi Martin,
This seems to be related to the same problem discussed here http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=118482
It was reported as a bug and fixed in version 8.4.0 http://world.episerver.com/support/Bug-list/bug/123201
Alf: Thanks for your help! Yes, unfortunately it behaves the same way inside a PageController.
Andreas: Thanks for that link! Upgrading to 8.11.0 solved it!
I've run into some unexpected behaviour with my EPi Server CMS 8.0.0.
The thing is that when I try to get children for a specific page. The children are not returned unless they have been loaded previously. I can load the children in edit mode by expanding the parent node or by debugging and getting a child, using the Immediate Window.
I've tried ContentLoader, ContentRepository and EPiServer.DataFactory.Instance.GetChildren. They all have the same problem.
If I expand the children of the page in edit mode once, they are returned in step 2 above. After recycling the AppPool the problem appears again.
Have any of you seen this?
Any ideas on how to solve it?
Site is protected by forms authentication. I have access to the pages (admin). The pages are published. It is a multi-lingual site.
Note:
EPiServer.DataFactory.Instance.GetChildren(pageReference, LanguageSelector.AutoDetect(true)) returns children but only in the master language (swedish).
EPiServer.DataFactory.Instance.GetChildren(pageReference, new LanguageSelector("en")) returns no children.
EPiServer.DataFactory.Instance.GetChildren(pageReference, new LanguageSelector("sv")) returns children.
This code is executed in the context of an System.Web.Http.ApiController. The requested language is passed as a query parameter. Could it be that the current culture is not set correctly?
Please advice.
/Martin
