EPiServer Login failed
My operating system is windows10, use Microsoft account login. When I visited the site VS was created, for example: http://localhost:54656/episerver . But i use the same Microsoft account login failed, prompting Login failed.
Is EPiServer not supporting the use of Microsoft account login?
Can only be replaced as a local account login?
Can someone give me a point?
Thanks in advance.
#133821
Sep 11, 2015 0:30
By default EPiServer use MultiplexingMembershipProvider, so you could use both WindowsMembershipProvider and SqlServerMembershipProvider.
You could create new users with administration privlilages from Admin Mode.
When you login for the first time you could use local administrator account or if you are logged into domain you could use domain account (it also need to be admin account).
#133848
Sep 11, 2015 20:52
Thank you very much, before I consider a mistake. I try to log in directly using the local Administrator account has been properly registered.
#134529
Sep 15, 2015 16:57
