Hello!
I found a solution that I publish here in case it helps somebody else in the same situation.
I had tried to add a Label to the controls collection with no success. The problem was that I was creating a EPiServer.XForms.WebControls.Label which for some reason couldn't be added. Changing to a System.Web.UI.WebControls.Label worked fine and the error message was displayed on the page. The code looks like this:
public void XForm_BeforeSubmitPostedData(object sender, SaveFormDataEventArgs e)
XFormControl control = (XFormControl)sender;
PageBase currentPage = control.Page as PageBase;
if (currentPage == null)
return;
//We set the current page that the form has been posted from
//This might differ from the actual page that the form property exists on.
e.FormData.PageGuid = currentPage.CurrentPage.PageGuid;
//Validation of email addresses
string emailAddress = e.FormData.GetValue("Email");
string repeatEmailAddress = e.FormData.GetValue("RepeatEmail");
if (emailAddress != null && repeatEmailAddress != null)
if (!emailAddress.Equals(repeatEmailAddress))
control.Controls.Add(CreateErrorLabel(CurrentBlock.ErrorMessage,"error"));
e.CancelSubmit = true;
And the CreateErrorLabel method:
private Label CreateErrorLabel(string labelText, string cssClass)
Label label = new Label();
label.CssClass = cssClass;
label.BackColor = Color.White;
label.Text = labelText;
return label;
Hello!
How can I show a custom error message in an XForm? I tried creating a Label and adding it to control.Controls collection but it didn't work. Now I've tried to do something like this
but e.ErrorMessage is not displayed anywhere. Having a control to display errors in the markup of the block (not in the form) doesn't make a difference either since the properties are not updated for some reason. It's frustrating. Can anyone help?
Thanks!
