If you take a look inside EditAttributes() method, it generates list of key/value pairs for EPiServer OnPage edit mode to understand which html element represents which PageType property. I haven't seen feature to add more than one EditAttributes() to the html element - to edit more than one PageType property.
To make this a good experience for the editor I think I would create a ButtonWrapperBlock and make your ButtonBlock local only (with AvailableInEditMode=false). Something like this:
[ContentType(DisplayName = "ButtonLocalBlock", GUID = "bc29dc00-46d4-48fc-8fdc-a7ffa2008313", Description = "", AvailableInEditMode = false)]
public class ButtonBlock : BlockData
[Display(Order = 1, GroupName = SystemTabNames.Content)]
public virtual string ButtonText { get; set; }
[Display(Order = 2, GroupName = SystemTabNames.Content)]
public virtual Url ButtonLink { get; set; }
[Display(Order = 3, GroupName = SystemTabNames.Content)] [SelectOne(SelectionFactoryType=typeof(ButtonSelectionFactory))]
public virtual string ButtonType { get; set; }
[ContentType(DisplayName = "ButtonBlock", GUID = "3039ab13-4cdb-46bc-85a6-3910bc5e4819")]
public class ButtonWrapperBlock : BlockData
[Display(Name = "Button")]
public virtual ButtonBlock Button { get; set; }
Then your ButtonBlock view would look like this:
@using EPiServer.Web.Mvc.Html
@model MyEPiServerSiteMVC.Models.Blocks.ButtonBlock
<a class="@Model.ButtonType" title="@Model.ButtonText" href="@Url.ContentUrl(Model.ButtonLink)">
@(string.IsNullOrWhiteSpace(Model.ButtonText) ? Html.Translate("/blocks/buttonblockcontrol/buttondefaulttext") : Model.ButtonText)
</a>
And your ButtonWrapperBlock view would look like this:
@using EPiServer.Web.Mvc.Html @model MyEPiServerSiteMvc.Models.Blocks.ButtonWrapperBlock @Html.PropertyFor(m => m.Button)
This will lead to a popup dialog when the editor clicks the button and he/she can set all the button properties all together.
Hello, Mattias Olsson
I have changed the markup in the class to @Model.ButtonType just before you posted this and my button is now showing up. I have implimented the wrapper as you have sugguested and I am getting nothing showing for my button in edit and as well as preview mode. I copied the code exactly. Is there something missing?
Do you have these files?
/Views/Shared/ButtonBlock.cshtml
/Views/Shared/ButtonWrapperBlock.cshtml
And you have created a new instance of the new ButtonWrapperBlock? If yes, it's strange it is not working.
I had buttonblock.cshtml in /views/blocks
and buttonwrapperblock.cshtml in /views/shared
so they both need to bein shared then?
I now have both in shared.
This made two block types in the menu when creating a new block. I chose the wrapper. I entered the setting and the block displayed in my content area. Clicking on the block did not render a popup editor but instead the normal editor in it's own page. I am not using the alloy site but have started from an empy project.
I have a list of button classes that I am making a selectable property in my block control. Depending on the selection I would like that button class to inject into the view for that button. Code below.
The factory: These are common bootstrap buttons
My Button Block Class:
My Button View:
When I replace @Html.EditAttributes with the actual name of the class the button shows. I have changed Model.buttonText to what you see now Model.ButtonType to try to capture what is being set for that property however it is running null. What step am I missing? Reference site
