Would be great if you could give a bit more info about customization available in the package (if any). Thanks!
This works perfectly, exactly what I was looking for. I couldn't install it as a nuget package, kept getting an error that the target frameowkr is not correct. It must be because there are no DLLs in the package? I then just downloaded the package and copied the required files from it.
A custom property for colorpicker to be used in edit mode.
Folow the below link:
https://www.nuget.org/packages/Liquidhub.Episerver.Colorpicker/
