Hi everyone,
I have found the solution on the log4net website.
You can create another logger for the assembly-namespace. Therefore you can set another logger to put only log of your classess.
I need to save logs for my application, but if I put the log level below ERROR I will get a lot of EpiServer logs. On the other hand, I need my logs to have different levels, since I want to do some debugging later.
What shall I do?
Thanks in advance,
Ashkan
