How can I get MembershipUser from the PrincipalInfo.CurrentPrincipal.GetUserGuid
I need to get the membership user and I have the EPiServer.Security.PrincipalInfo.CurrentPrincipal.GetUserGuid() in a variable.
I tried Membership
Membership.GetUser(guidVariable);
but it returns null, since the GetUserGuid property is not the membership GUID.
After a lot of searches, I came up with this code:
Mediachase.Commerce.Customers.CustomerContext customerContext = new Mediachase.Commerce.Customers.CustomerContext();
Mediachase.Commerce.Customers.CustomerContact userContact = customerContext.GetContactById(modifierId);
return Membership.GetUser(userContact.ProviderUserKey.ToString());
which simes to work but
ProviderUserKey is Obsolete.
What shall I do?
Thanks in advance,
Ashkan
#142240
Dec 07, 2015 10:14
You can use userContact.PrimaryKeyId instad.
/Q
#142245
Dec 07, 2015 13:30
Hi Quan,
Thanks for the reply.
Unfortunately, the userContact.PrimaryKeyId does not contain the "username" nor the membershipGUID.  It is completely the same as the value that I had originally (from CurrentPrincipal.GetUserGuid), So I can't use it to retrieve data from Membership.
It is the GUID of the episerver contact, not the membership.
#142246
Dec 07, 2015 14:02
Can you try with CustomerContext.GetUserForContactId(PrimaryKeyId) to see if it works for you?
(Btw- mentioning the version in your post will be a big help ;) )
/Q
#142247
Dec 07, 2015 14:07
<p>Hi Quan,</p> <p>Thanks again for the reply&nbsp;and sorry that I didn't mention my EPIServer version (which by the way is 8.11.0.0).</p> <p>The method you mentioned was the one that I needed.</p> <p></p> <p>Thanks again&nbsp;</p> <p>Best Regards,</p> <p>Ashkan</p>
#142248
Dec 07, 2015 14:52
