episerver dds generics returns no value
I am using EPIServer 8.12.
I've implemented a class using dds. The problem is when I turn my class to a generic class and I pass the same class if returns no value.
for instance, I have this code which works fine and returns 8 lines:
  var items = store.Items().Where(i => i.State == Enums.QueueItemState.Queued || i.State == Enums.QueueItemState.Retrying).ToList();
(QueueableEmailItem : IDynamicData)
now I change the code to
and call it with the same class. (where T : IDynamicData)
it returns no results.
Funny story is that if I change the code to code below which fetchs the class before adding the where clause, it will work fine
var items = store.Items().ToList();
var undoneItems = items.Where(i=> i.State == Enums.QueueItemState.Queued || i.State == Enums.QueueItemState.Retrying).ToList();
Is there any problem with generics?
Anyone know what shall I do?
#142655
Dec 17, 2015 16:27
