You can check out the guide
http://world.episerver.com/documentation/Items/Installation-Instructions/Installing-EPiServer-updates/Upgrading-to-EPiServer-75-CMS/
Basically start with upgrading to 6 R2 then continue to 7 then 7.5.
Use deployment center and not nuget packages for upgrade. Best to keep a fresh demo site close to steal some settings from.
Looks like you have a problem with vpp. Tried to upgrade directly to 7.5? Used nuget instead of deployment center?
At 7.5 you also need to migrate vpp files to new media files. There is a tool that does that.
I'm trying to upgrade a CMS 6 installation to CMS 7.5 but whithout success. This is what I get:
_____________________________________
Verifying whether specific add-ons should be updated before site upgrade.
An unhandled error has occured:
Virtual path to protected packages is invalid: ''.
When executing
At C:\Program Files (x86)\EPiServer\CMS\7.5.394.2\Upgrade\System Scripts\Upgrad
e Site To 7R2 (SqlServer).ps1:18 char:35
+ $addOnsToBeUpdated = Get-EPiAddOns <><><>< -ApplicationPath $siteRoot -ApiPath>>>
$apiRoot `
Get-EPiIsBulkInstalling
At C:\Program Files (x86)\EPiServer\CMS\7.5.394.2\Upgrade\System Scripts\Upgrade Site To 7R2 (SqlServer).ps1:18 char:35
+ $addOnsToBeUpdated = Get-EPiAddOns <><><>< -ApplicationPath $siteRoot -ApiPath $apiRoot `>>>
System.Configuration.ConfigurationErrorsException: Virtual path to protected packages is invalid: ''.
at EPiServer.Packaging.Configuration.PackagingConfiguration..ctor(IHostingEnvironment environment, EPiServerPackagingSection packagingSection, EPiServerFrameworkSection frameworkConfiguration, String binPath)
at EPiServer.Packaging.CommandLine.PackagingHelper.InitConfiguration()
at EPiServer.Packaging.CommandLine.PackagingHelper..ctor(String applicationPath)
at EPiServer.Packaging.CommandLine.PackagingCommands.GetInstalled(Object cmdLet)
at EPiServer.Install.Packaging.Cmdlets.GetAddOnsCmdLet.ProcessRecord()
at System.Management.Automation.Cmdlet.DoProcessRecord()
at System.Management.Automation.CommandProcessor.ProcessRecord()
Can someone please suggest I way forward?
Best regards
//Daniel
