You may look into content area tags. This I guess is preferred way to customize look and feel of the same content type across different "hosts" (content areas).
How would be the way to define different view templates when displaying a page in a contentarea????
For example, I would like that page type pt1 would render as template1 in a contentarea of page type pt2, and at the same time renders
as template2 in a contentarea of pagetype pt3.
| template1 in a contentarea of pt2
pt1 -> |
| template2 in a contentarea of pt3
I solved it including another page pt4 that inherits from pt1, so:
- pt1 renders always with template1 in contentarea of pt2
- pt4 renders always with template2 in contentarea of pt3
Is there a better way to get this working without using inheritance??? Do you think it's a good or a silly solution to solve this problem???
