In the error message it says (ContentLink=251), so if you search for 251 in your source installation you can probably find the content causing this. If not you can modify the url in edit to point to 251.
Not sure how to solve it though, but try to republish it and then do the process again.
I'm trying to export all content from one Episerver 8 CMS website, and import it to another Episerver 8 CMS website, with some changes at PageType level.
Exporting data is ok, but when trying to import, I get the following error mensage:
Import has been canceled
The following errors have occurred:
[Importing content 251] Exception: Using SaveAction.Save + SaveAction.ForceCurrentVersion on published content is not allowed (ContentLink=251)
What does it mean? how can I locate the item that's provoking this error? how can I solve it???
Regards
