I have the same problem. Did you solve this problem?
Best Regards
Anders
Hi Anders (and Hugo).
We've previously done numourous implementations relying on a custom HttpHandler for Media in Episerver. It has e.g. been used for tracking downloads and enforcing access control for first download (kind of a gated approach to documents).
I've shared some of the important code from our implementation as a Gist on Github. I hope that can help you move forward. Be aware that it has been taken out a bigger context.
https://gist.github.com/casper-rasmussen/8ba5a1135fadc79a87b9d53cc409fc5a
Casper Aagaard Rasmussen
Hi Casper,
Thank you very much. We changed some code in your example and now everything is working as we like :)
Best Regards
Hi, there,
I need to do some extra processing on a media type. I am following the code sample provided on this page.
http://world.episerver.com/documentation/items/developers-guide/episerver-cms/75/content/assets-and-media/media-types-and-templates/
I have confirmed that the handler gets called when that media type is called. The issue is that it is not returning the pdf file.
So I have two questions. First, is there a method that the framework provides to serve blobs?
And the second question. In case there is no method to server blobs, is there a method to turn blobs into a Binary Stream?
Thanks in advance.
