How to install EPiServer Search on 7.5
I got to a point where I tried using a EPiServer SearchDataSource for the first time in 7.5 and I get an error message saying I need to install EPiServer Sarch. I suppose I do this from the Deployment Center but when I try to install the module my site doesn't show up in the list of available sites to install to.
What are the steps in this procedure? I can't seem to find any info on it.
#89444
Aug 17, 2014 19:49
Try to just click show all sites and you will see it
#89447
Aug 18, 2014 7:02
1- Run deployment center
2- Version 7.5.394.2 -> Modules select "Install EPiServer Search"
3- Select your site (Check "Show all sites" if your site doesn't show up ).
4- Select the folder where "Search Index" will be stored.
5- Finish
#89451
Aug 18, 2014 9:06
So I did and after clicking "Show all sites" followed by "Next" I get this error message:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ApplicationException: The web.config file for this site does not appear to match the EPiServer schema - could not find a matching node
at EPiServer.Install.WebServer.WebApplication.get_SiteConfigNode()
at EPiServer.Install.WebServer.WebApplication.GetEPiServerCMSConnectionStringName()
at EPiServer.Install.WebServer.WebApplication.get_ConnectionStringNode()
at EPiServer.Install.WebServer.WebApplication.get_SiteDbConnectionString()
at EPiServer.Install.UI.Controls.SelectSiteControl.Wizard_ValidatingStep(Object sender, StepValidationEventArgs e)
at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
at EPiServer.Install.UI.WizardBase.OnStepValidating(UserControl currentStepControl, Int32 currentStepIndex)
at EPiServer.Install.UI.WizardFrameForm.DoButtonAction(ButtonAction action)
at EPiServer.Install.UI.WizardFrameForm.Button2_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EPiServerInstall
Assembly Version: 1.1.1997.0
Win32 Version: 1.1.1997.0
CodeBase: file:///C:/Program%20Files%20(x86)/EPiServer/Shared/Install/EPiServerInstall.EXE
Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EPiServerInstall.Common.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/EPiServerInstall.Common.1/v4.0_1.1.1997.0__8fe83dea738b45b7/EPiServerInstall.Common.1.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Management.Automation
Assembly Version: 1.0.0.0
Win32 Version: 6.1.7601.17514
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management.Automation/1.0.0.0__31bf3856ad364e35/System.Management.Automation.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Microsoft.PowerShell.Commands.Diagnostics
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.PowerShell.Commands.Diagnostics/1.0.0.0__31bf3856ad364e35/Microsoft.PowerShell.Commands.Diagnostics.dll
System.Configuration.Install
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.Install/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
Microsoft.WSMan.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.WSMan.Management/1.0.0.0__31bf3856ad364e35/Microsoft.WSMan.Management.dll
Microsoft.WSMan.Runtime
Win32 Version: 6.1.7600.16385
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.WSMan.Runtime/1.0.0.0__31bf3856ad364e35/Microsoft.WSMan.Runtime.dll
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Microsoft.PowerShell.Commands.Utility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.PowerShell.Commands.Utility/1.0.0.0__31bf3856ad364e35/Microsoft.PowerShell.Commands.Utility.dll
Microsoft.PowerShell.ConsoleHost
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.PowerShell.ConsoleHost/1.0.0.0__31bf3856ad364e35/Microsoft.PowerShell.ConsoleHost.dll
Microsoft.PowerShell.Commands.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.PowerShell.Commands.Management/1.0.0.0__31bf3856ad364e35/Microsoft.PowerShell.Commands.Management.dll
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.ServiceProcess
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
Microsoft.PowerShell.Security
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.PowerShell.Security/1.0.0.0__31bf3856ad364e35/Microsoft.PowerShell.Security.dll
System.DirectoryServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.DirectoryServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.DirectoryServices.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
EPiServerInstall.CMS
Assembly Version: 7.5.394.2
Win32 Version: 7.5.394.2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/EPiServerInstall.CMS/v4.0_7.5.394.2__8fe83dea738b45b7/EPiServerInstall.CMS.dll
EPiServer.Framework.Install
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/EPiServer.Framework.Install/v4.0_7.5.394.2__8fe83dea738b45b7/EPiServer.Framework.Install.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.Web.Administration
Assembly Version: 7.0.0.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Web.Administration/7.0.0.0__31bf3856ad364e35/Microsoft.Web.Administration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
#89544
Aug 19, 2014 19:52
#89545
Aug 19, 2014 19:52
#89546
Aug 19, 2014 19:53
Also something about it not being able to find a matching site node in web.config. Any tips?
#89547
Aug 19, 2014 19:59
First. Make shore your site works local so you do not have any error.
Does your site works if you points a local IIS to it?
#89549
Aug 19, 2014 21:01
Yes, works fine. I'm working in it as we speak. Haven't got no site node in web.config, though. What's that about?
#89550
Aug 19, 2014 21:14
Strange, got the same error earlier today when a nuget upgrade went wrong.
Try to install search from nuget packet and the create a new site from the EPiServer visual studio plugin and copy the web service from it.
#89551
Aug 19, 2014 21:33
Sorry for the late reply.
I tried installing a new site and I get the same error after the same procedure. And the NuGet (install-package episerver.search) doesn't work. "Unable to find package...".
What does the installer do? Add dll and some web.config lines?
#89771
Aug 25, 2014 21:13
I'm still struggling with this and I'm about to reach the point to where I can't do anything else but solve it. Anyone has any more suggestions on what to do or is this a bug that I need to report?
#90335
Sep 07, 2014 20:35
I successfully installed Episerver Search the other day using the instructions here. It was done through Nuget (not deployment center) and it was surprisingly easy. It will add a dll, an svc to your project and some changes in web.config. The only manual thing I needed to do was to update baseUri in web.config to reflect my local url. That's all. Hope this helps.
#90545
Sep 11, 2014 23:29
Sorry for the late reply, Johan. I tried another alternative (I think it was "install indexing service") and then it ran fine. Thanks for the link, though. It helped me to understand the web.config part.
#90785
Sep 17, 2014 20:54
