Alloy MVC N00b question 2
In the Alloy MVC project there is a model, partial view and controller for a image file. But it's never used when rendering images on the site? Why not if so?
Cheers
David
#83047
Mar 25, 2014 10:47
This is being used when dragging images into a content area. It enables you to easily customized the rendering
#83056
Mar 25, 2014 12:13
Tank you. So you do not use this when rendering images on a page outside a content area?
#83066
Mar 25, 2014 12:58
When rendering an images as a property on a page, a display template is used by default. Check out Image.cshtml under DisplayTemplates in the alloy project
#83071
Edited, Mar 25, 2014 13:21
When i look at Index.cshtml for ProductPage i see an image beeing rendered like this:
<div @Html.EditAttributes(x => x.CurrentPage.PageImage)>
        <img src="@Url.ContentUrl(Model.CurrentPage.PageImage)"/>
 </div>
Why is there an <img> here if you should use image.cshtml? Is not the display template used here? If not, is there an example where it is used?
#83080
Mar 25, 2014 14:56
The display template is not used there. It would have been had you typed @Html.PropertyFor(x => x.CurrentPage.PageImage).
This is done in JumbtronBlockWide.
The way it has been done in ProductPage could be useful if you want to render your image a bit different than normally, but do not want to create a new display template to do that.
#83082
Mar 25, 2014 15:05
Thank you for your help!
#83086
Mar 25, 2014 15:45
One more question about this:
How do i set the alt text to the Copyright property from the image when the image.cshtml look like this?
@model EPiServer.Core.ContentReference
@if (Model != null)
    <img src="@Url.ContentUrl(Model)" alt="" />
#85410
Apr 24, 2014 14:11
