Virtual directory (IIS) and asp-script problem
This is not all EPiServer but maybe someone here has an answer. I have an asp-script in a folder. I have created a virtual directory in IIS (7.5) pointing to my child map and I'm having some problems getting the script to run. I have added the following to the web.config (in the child map - mychildfolder - to my EPiServer solution map):
<location path="mychildfolder" inheritInChildApplications="false">
<system.webServer>
<directoryBrowse enabled="true" />
<handlers>
<add name="ASP" path="*.asp" verb="*" modules="IsapiModule" scriptProcessor="C:\Windows\System32\inetsrv\asp.dll" resourceType="Unspecified" preCondition="bitness64" />
</handlers>
<defaultDocument>
<files>
<add value="index.asp" />
</files>
</defaultDocument>
</system.webServer>
</location>
When I try to run the script I get 403 access problems... and the index.asp file doesn't run - I get returned to my default  Page not found. The IIS_IUSER is added to the map and has read rights. Anyone with an idea of what the problem could be?
#75347
Sep 25, 2013 16:44
Is the virtual directory just a virtual directory or it's own IIS Application?
#77710
Nov 25, 2013 11:18
