Google shows 404 on EPiTrace
We've got 2750 404 errors in Google Webmaster Tools cause by EPiTrace. Any idea why this is? The links can look something like EPiTrace/Handlers/TrackerHandler.ashx?pageId=1857
#72350
Jun 13, 2013 15:16
Hello,
Could you, please, provide more information:
  • Which EPiServer CMS version are you using?
  • Does EPiTrace works as expected on the site?
  • Does those links actually return 404 when you try to reach them?
  • If you view page source in the browser, how does the path to the TrackerHandler.ashx looks like?
#72438
Jun 17, 2013 15:05
We're in 6.1.379.0.
I can't even find the EPiTrace interface and the boxes related to it also gives errors so I'm gonna go with "No, it doesn't work." :)
Yes, they do.
It looks to be correct. /EPiTrace/Handlers/TrackerHandler.ashx?pageId=21001
Do you think it needs a re-install? Is it "safe" to do so?
#72447
Jun 17, 2013 16:40
EPiTrace is the old name for Live Monitor. You should have a "Live Monitor" menu item under the CMS menu item in the global menu.
One possible reason for having those 404 is that TrackerHandler.ashx is not registered in the web.config. Check if you have this under your /configuration/system.webServer/handlers section (for IIS7): <add name="EPiTraceTracker" path="TrackerHandler.ashx" verb="*" type="EPiServer.Trace.CMS.Handlers.TrackerHandler" />.
Reinstall should be quite safe.
#72455
Jun 17, 2013 17:51
if it is not working you are probably missing the config-settings but stil have the EPiServer Trace dll in you binary folder. Maybe you have installed them earlier or as mentioned you are using an old version. If you remove all binaries and the configs-settings, just search for "trace" you will be able to remove it from your solution. Or you could just reinstall the new version.
#72459
Jun 17, 2013 21:56
Hmm. Very strange. The dll is in the bin-folder, and the handler-line is in web.config. No "Live Monitor" in the CMS menu though. I'll try to reinstall and get back to you.
#72482
Jun 18, 2013 16:09
Still haven't solved this so maybe it's time for another try. The instructions reads "Download and unzip the Live Monitor.zip" but where do I download this zip-file??
#74210
Aug 22, 2013 13:49
CMS 6R2 installation has Live Montir.msi - this is the installer that adds Live Monitor to the Deployment Center. Here you can find Live Monitor installation instructions for CMS 6R2.
#74212
Aug 22, 2013 13:56
