Hello Thusitha,
There is a workaround for the issue: http://world.episerver.com/Blogs/Jeff-Wallace/Dates/2012/12/Visual-Studio-Extension--Error-When-Creating-a-New-Site/. Have you tried it?
Thanks Sergii!
I just removed the mentioned attribute and it worked. Also I had to add my domain account as a SQL Login with sufficient privileges to create the DB.
Regards,
Thusitha
I'm unable to create a new EPiServer using a VS 2010. I'm on EPiSerer 7. Following is the error I'm getting:
An unhandled error has occured:
Filename: \\?\C:\Users\thhettige\Documents\IISExpress\config\applicationhost.co
nfig
Line number: 135
Error: Unrecognized attribute 'CLRConfigFile'
When executing
At C:\Program Files (x86)\EPiServer\CMS\7.0.586.1\Install\System Scripts\Instal
l Site (No Database).ps1:191 char:57
+ $workerProcessGroups = $webServer.WorkerProcessAccounts <<<< ($wizard.Site.A
ppPoolName)
True
Get-EPiIsBulkInstalling
An error has occured and the transaction will be rolled back
Rolledback
nfig
Line number: 135
When executing
ppPoolName)
At C:\Program Files (x86)\EPiServer\CMS\7.0.586.1\Install\System Scripts\Install Site (No Database).ps1:191 char:57
+ $workerProcessGroups = $webServer.WorkerProcessAccounts <<<< ($wizard.Site.AppPoolName)
System.Management.Automation.ParentContainsErrorRecordException: Exception calling "WorkerProcessAccounts" with "1" argument(s): "Filename: \\?\C:\Users\thhettige\Documents\IISExpress\config\applicationhost.config
Line number: 135
What am I missing here?
Regards,
Thusitha
