Possibility to override "default.aspx"?
When a user visits the bare domain url for an episerver site (CMS6R2), that is for example http://www.myepisite.com the default behaviour seems to be to redirect the user to the site defined as startpage in episerver.config. Is there anyway to override this behaviour, if I for example want to show a splash screen or do custom redirect?
#71060
May 08, 2013 10:35
A few simple ways:
- go to edit mode and set your startpage to be a Shortcut to any other page (will redirect every time someone visits your startpage - not recommended)
- put some logic in the OnInit/OnLoad methods in default.aspx to do a custom redirect or show a splash/popup if condition X is true.
You should also be aware that redirecting from the startpage might lead to URL confusion for search engines unless you properly handle your HTTP status codes.
#71067
Edited, May 08, 2013 12:20
The safest way is for sure to put some logic in the OnInit/OnLoad methods in default.aspx as Arild says.
I did something once where a cookie was used to only show a splash screen once. You could easily have the splash as the default view always and act on a ?unsplash querystring parameter or similiar as an example of "X is true".
#71084
May 08, 2013 19:01
