The problem is that the system cannot instantiate your initializable module because it is abstract.
You can find more information about initializable module or add-on initializer in Add-ons developer guide.
Also see example implementations in Sample add-on source code.
Consider implementing usual non-abstract public initializable module, if you need only initialization logic that should run when site starts. Something like the following:
[InitializableModule]
public class MyInitializableModule : IInitializableModule
/// <summary>
/// Executes on initialization.
/// </summary>
/// <param name="context">The context.</param>
/// <summary>
/// Executes on uninitialization.
/// </summary>
/// <summary>
/// executes on preload
/// </summary>
/// <param name="parameters">The parameters.</param>
Consider inheriting your initializer from EPiServer.Packaging.PackageInitializer class if you need to run some code after add-on is installed, updated or before add-on is removed. Implement corresponding methods of base class. Note that package/add-on initializer is also initializable module, don't forget to call base implementation when overriding Initialize, Uninitialize and Preload methods.
[ModuleDependency(typeof(Packaging.PackagingInitialization))]
[ModuleDependency(typeof(Web.InitializationModule))]
public class MyAddonInitializer : Packaging.PackageInitializer
/// <summary>
/// Executes after add-on is installed.
/// </summary>
public override void AfterInstall()
/// <summary>
/// Executes after add-on is updated.
/// </summary>
public override void AfterUpdate()
/// <summary>
/// Executes before add-on is uninstalled.
/// </summary>
public override void BeforeUninstall()
/// <summary>
/// Initializes the module.
/// </summary>
public override void Initialize(InitializationEngine context)
base.Initialize(context); // and then do something specific for this add-on initializer...
Hello guys,
I create my NuGet Package to install my add on. After install I restart the iss and I get this message:
Cannot create an abstract class.
I don't know why I can't write in a log as well.
Some one can help me?
namespace Project.Manager
[ModuleDependency(typeof(EPiServer.Packaging.PackagingInitialization))]
public abstract class PackageInitializer : IPackageNotification
//: IInitializableModule
static ILog log = log4net.LogManager.GetLogger(typeof(PackageInitializer));
public PackageInitializer()
public void AfterInstall()
log.Error("Begin");
WriteConnectionString();
CopyFiles();
//Execut SQL creation.
log.Error("Done");
public void AfterUpdate()
log.Error("AfterUpdate");
//System.IO.Directory.CreateDirectory("AfterUpdate");
//throw new NotImplementedException();
public void BeforeUninstall()
//System.IO.Directory.CreateDirectory("BeforeUninstall");
