Create new version of file programmatically
I'm adding files to a custom vpp folder which uses the default VirtualPathNonUnifiedProvider:
var pageRootDirectory = (UnifiedDirectory)GenericHostingEnvironment.VirtualPathProvider.GetDirectory("~/CatalogImages/");
var versioningDirectory = pageRootDirectory as VersioningDirectory;
VersioningFile versioningFile = (VersioningFile) pageRootDirectory.CreateFile(resizedFileName);
I thought it whould always create a new version of a file when I use the create file but it doesn't, because the second time I create the same file it will throw an exception.
My question is how do I create a new version of a file?
Thanks in advanced,
Jeroen Slor
#61725
Sep 28, 2012 18:10
The VPP needs to be a VirtualPathVersioningProvider. You can check that in EPiServer.config. And this code should work:
UnifiedDirectory unifiedDirectory = HostingEnvironment.VirtualPathProvider.GetDirectory(path) as UnifiedDirectory;
UnifiedFile unifiedFile = HostingEnvironment.VirtualPathProvider.FileExists(filePath)
                                ? HostingEnvironment.VirtualPathProvider.GetFile(filePath) as UnifiedFile
                                : unifiedDirectory.CreateFile(filePath);
using (Stream stream = unifiedFile.Open(FileMode.OpenOrCreate, FileAccess.Write))
    // Write to the stream
#61727
Sep 29, 2012 0:11
Thanks for the quick reply. What I whould like to achieve is if the file already exists, that I can create a new version of this file. How can I do this?
Thanks!
Jeroen
#61730
Sep 29, 2012 11:36
If you're using a VirtualPathVersioningProvider, there will be a new version of the file, if it exists already.
#61732
Sep 30, 2012 14:48
So on the moment I see that the file already exists and I use the GetFile method I get a new version of this file? Don't I have to manualy create one? How do I save the new version of this file without overwriting the current.
Thanks in advanced,
Jeroen
#61733
Sep 30, 2012 17:30
No you don't get a new version, but one will be created when you write to the stream. You don't have to do more than write to stream, it just works magically.
#61734
Sep 30, 2012 17:36
Ah ok it's getting clear for me thanks! I'll give it a shot tomorrow and let you know.
#61735
Sep 30, 2012 19:45
