EPiServer 4.60 Handler
Hello,
i would like someone to help me with this Handler in episerver 4.60. Is to request a property name and a pageid.
What means is when i run in the browser an address to show me the text from another page.
Sorry for my english
Here is the code:
using System;
using System.IO;
using System.Collections;
using System.ComponentModel;
using System.Data;
using System.Web;
using System.Web.SessionState;
using System.Web.UI;
using System.Web.UI.HtmlControls;
using System.Web.UI.WebControls;
using EPiServer;
using EPiServer.Core;
using EPiServer.Core.Html;
namespace Intranet.Handlers
    public class EpiPropertyDataRetreiver : IHttpHandler
        /// <summary>
        /// You will need to configure this handler in the web.config file of your
        /// web and register it with IIS before being able to use it. For more information
        /// see the following link: http://go.microsoft.com/?linkid=8101007
        /// </summary>
        #region IHttpHandler Members
        public bool IsReusable
            // Return false in case your Managed Handler cannot be reused for another request.
            // Usually this would be false in case you have some state information preserved per request.
            get { return true; }
        public void ProcessRequest(HttpContext context)
            //HttpResponse response = context.Response;
            //HttpRequest request = context.Request;
            //HttpServerUtility server = context.Server;
            var pageid = context.Request.QueryString["pageid"];
            var propertyname = context.Request.QueryString["propertyname"];
            int id = 11706;
            DataFactory dataFactory = Global.EPDataFactory;
            PageReference reference= new PageReference(id);
            PageData pd = dataFactory.GetPage(reference);
            string s = pd.Property[propertyname].ToString();
            // get page from epi
            // get property value that is in the page.
            context.Response.Write("propertyname");
        #endregion
#60834
Aug 28, 2012 11:06
