If you want to serve them from a cookie-free domain you can't use access rights for the files.
One approach would be to do a custom url-rewriter and rewrite the paths for static files and switch between, let's say, 5 subdomains and add those as hostheaders to the site.
This way you don't get cookie-free, but a poor mans CDN :)
If you want to serve the files really fast you should serve them as static files straight from IIS and not through a handler.
A common step in optimizing sites is to make sure all static resources (images, css, javascript) are served from a cookieless domain, i.e. a subdomain to the main site which the browser won't send cookies to. I wonder how to set this up using EPiServer? I guess one approach would involve setting up a handler that intercepts all requests to static resources and rewrite them to the subdomain?
