The EPiServer PageTree control doesn't support multiple sources. I'd done multi-source trees with the asp:TreeView-control, I guess you can use it for your needs?
Thanks Henrik.
I replaced PageTree with Tree View. Is there a way to get the similar LayOut as we have in PageTree(Horizonta) instead of vertical.
The asp:TreeView does not support that but it should be possible to style the rendered HTML to your need.
Hi, I am facing a problem with PageTree contol. We are using this control to display menus for Sitemap. Our problem is that we need data from two different pages(they are under different folders in EpiServer). But as per my knowledge PageLink property of PageTree can have only one PageReference as source. Is it possible to have two PageReference as a source or PageDataCollection as a source for PageTree.
PageTree.PageLink = (PageReference)CurrentPage
PageTree.DataBind()
Instead i want something like PageTree.PageLink = (PageReference)CurrentPage + (PageReference)SharedPage.
Or i can use PageDataCollection as datasource for PageTree. Is PageTree.DataSource = PageDataCollection possible.
Please help, this is holding my work.
Thanks a lot
